[GRASS-dev] [GRASS GIS] #494: break in importing and cleaning very large vector datasets
trac at osgeo.org
Mon Jul 28 01:59:43 PDT 2014
Reporter: gisboa | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.0
Component: Vector | Version: 6.4.2
Resolution: | Keywords: vector import clean build
Platform: MSWindows 7 | Cpu: x86-64
Description changed by neteler:
Old description:
> I try to use Grass with large vector files, with sizes up to 0,5GB, this
> usually results in errors during import, or if not during import, then at
> least while cleaning them. Both on Mac (Leopard intel) and Linux
> (openSuse 11 (32 and 64bit). It doesn't seem to be a problem with the
> data, as I can process all data when splitting the import, and handle the
> various slices separately.
> Files are too large to attach...
> Wouter
> Mac OSX
> GRASS 6.4.0RC3 (nl-rdn):/data/grassdb/nl-rdn > v.clean --o
> input=top_top10vec_gebouwen output=top_top10vec_geb2 tool=bpol
> Tool: Threshold
> Break polygons: 0.000000e+00
> Copying vector lines...
> Rebuilding parts of topology...
> Building topology for vector map <top_top10vec_geb2>...
> Registering primitives...
> 6041168 primitives registered
> 25000849 vertices registered
> Number of nodes: 6037532
> Number of primitives: 6041168
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 3021055
> Number of centroids: 3020113
> Number of areas: -
> Number of isles: -
> Tool: Break polygons
> v.clean(22861) malloc: *** mmap(size=275042304) failed (error code=12)
> *** error: can't allocate region
> *** set a breakpoint in malloc_error_break to debug
> ERROR: G_realloc: unable to allocate 275040036 bytes at
> break_polygons.c:188
> Linux 64bit
> Number of points: 0
> Number of lines: 0
> Number of areas: -
> Number of isles: -
> ERROR: G_realloc: unable to allocate 34400040 bytes at
New description:
least while cleaning them. Both on Mac (Leopard intel) and Linux (openSuse
11 (32 and 64bit). It doesn't seem to be a problem with the data, as I can
process all data when splitting the import, and handle the various slices
separately.
Wouter
Mac OSX
Tool: Threshold
Number of points: 0
Number of lines: 0
Number of areas: -
Number of isles: -
Linux 64bit
Number of points: 0
Number of lines: 0
Number of areas: -
Number of isles: -
Ticket URL: <https://trac.osgeo.org/grass/ticket/494#comment:6>
