[GRASS-dev] [GRASS GIS] #1369: setPrompt: command not found in GRASS7-svn
trac at osgeo.org
Mon Jul 28 19:54:30 PDT 2014
Reporter: moovida | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.0
Component: Startup | Version: svn-trunk
Resolution: wontfix | Keywords: shell, prompt
Platform: Linux | Cpu: Unspecified
Changes (by hamish):
* keywords: => shell, prompt
Comment:
for me this was working fine for me last time I had a MASK map set,
GRASS7> echo $PROMPT_COMMAND
'/home/hamish/src/grass/svn/trunk/dist.x86_64-unknown-linux-
gnu/etc/prompt.py'
As such, I would suggest that this bug is already fixed, not wontfix.
the place the prompt.py is set is in lib/init/grass.py line ~1085.
Prompt.py is also in lib/init/ in the source tree.
fwiw I doubt that has to be or should be a python script, and I think it
only slows things down to have it as such. By definition the bash prompt
is going to have a Bourne shell already present and already cached in
memory, and launching a python process is much more expensive than a built
in function().
ISTR some trouble with this last time I tried G7 from the cmd.exe line on
Windows, it had trouble finding the right python interpreter? Would need
to recheck if that is still the case. Rather that worry about fixing that
I'd again suggest to just put it back to a shell script and avoid the
headache.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1369#comment:4>
