[GRASS-dev] GRASS & QGIS: the future
Tue Jul 29 14:00:12 PDT 2014
Markus Neteler wrote:
> >> > Can you try the attached patch? The new function should be used like:
> >> >         if (setjmp(*G_fatal_longjmp(1))) {
> >> >             // this will be executed on fatal errors
> >> Works. Can I hope the patch will find a way to 7.0.0?
> > Committed in r60590.
> Glynn, should I backport that to relbranch70?
I suppose so.
