[GRASS-dev] [GRASS GIS] #2252: wxGUI vector digitizer passing unescaped text to database
trac at osgeo.org
Tue Jul 29 16:29:03 PDT 2014
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: security, code injection, SQL injection, data loss, v.db.update | Platform: Unspecified
Cpu: Unspecified |
Comment(by wenzeslaus):
If we decide to do this separately in each usage of database (places in
GUI and each module for which it makes sense), there some people already
[http://stackoverflow.com/questions/6514274/how-do-you-escape-strings-for-
sqlite-table-column-names-in-python tried something] like this and there
is even a
[https://gist.github.com/1083518/584008c38a363c45acb84e4067b5188bb36e20f4
Gist] dedicated to it.
Here is the code from Gist:
#!python
import codecs
def quote_identifier(s, errors="strict"):
encodable = s.encode("utf-8", errors).decode("utf-8")
nul_index = encodable.find("\x00")
if nul_index >= 0:
error = UnicodeEncodeError("utf-8", encodable, nul_index,
nul_index + 1, "NUL not allowed")
error_handler = codecs.lookup_error(errors)
replacement, _ = error_handler(error)
encodable = encodable.replace("\x00", replacement)
return "\"" + encodable.replace("\"", "\"\"") + "\""
Given a string single argument, it will escape and quote it correctly or
raise an exception. The second argument can be used to specify any error
handler registered in [the `codecs` module][8]. The built-in ones are:
- `'strict'`: raise an exception in case of an encoding error
- `'replace'`: replace malformed data with a suitable replacement marker,
such as `'?'` or `'\ufffd'`
- `'ignore'`: ignore malformed data and continue without further notice
- `'xmlcharrefreplace'`: replace with the appropriate XML character
reference (for encoding only)
- `'backslashreplace'`: replace with backslashed escape sequences (for
encoding only)
This doesn't check for reserved identifiers, so if you try to create a new
`SQLITE_MASTER` table it won't stop you.
It is using Python package [https://docs.python.org/2/library/codecs.html
codecs].
But still it would be probably ideal to use database API for it and expose
this through GRASS C API. Additionally, it would be interesting to do
something PyGRASS tried to do: use Python API directly but use some GRASS
functions to obtain the right database (backend).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2252#comment:3>
