[GRASS-dev] [GRASS GIS] #2382: d.legend: integer map legends should not be flipped upside-down
trac at osgeo.org
Wed Jul 30 09:37:18 PDT 2014
Reporter: neteler | Owner: hamish
Type: defect | Status: assigned
Priority: normal | Milestone: 7.0.0
Component: Display | Version: svn-releasebranch70
Keywords: d.legend | Platform: All
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:1 hamish]:
> So it comes down to the question of is the data categorical (in which
case smallest value is at the top) or continuous gradient which happens to
be stored as integers (in which case smallest values is at the bottom).
Since CELL maps can be used for both there is no single correct answer to
that, and so the module goes with the logic that if the range of available
cats or the frame size happens to change by a little bit, pushing it over
the threshold, it will change the boxes into thin lines, but the overall
view will remain the same, it has just gone into "compressed mode".
In my view, the order should be defined by the gradient/box legend, not by
the type of the map since it is not reliable. Gradient would have low
values in the bottom, and boxes would be ordered in the opposite
direction. This behavior could create less confusion and would be expected
in most cases, in my opinion.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2382#comment:4>
