[GRASS-dev] [GRASS GIS] #2384: v.vect.stats not in GUI
GRASS GIS trac at osgeo.org
Wed Jul 30 17:08:31 PDT 2014
 Reporter:  alanglen89  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.4.5
Component:  Vector      |     Version:  unspecified
 Keywords:              |    Platform:  MSWindows 8
      Cpu:  x86-64      |
 The module v.vect.stats is included in version 6.4.5, but is missing or is
 hard to find using the GUI. Looking through all the buttons and searching
 with the search module gives no results. However, I found using the
 Command Console, it is possible to type v.vect.stats to access/run the
 module.
 Request: Add v.vect.stats to the GUI menu.
 Thank you for your continuing to improve GrassGIS!
Ticket URL: <http://trac.osgeo.org/grass/ticket/2384>
