[GRASS-dev] Significant r.in.gdal speed-up: predefined 300 MiB as default cache size
Yann Chemin ychemin at gmail.com
Wed Jul 30 18:58:47 PDT 2014
WoW ! Thanks Markus !
On 30 July 2014 21:42, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> I have made a modification to r.in.gdal for a (significant) speedup
> (both in trunk and relbranch70).
> A nice test case is the European 25m elevation model which is a 23GB
> GeoTIFF file of 4.8 billion raster cells:
> gdalinfo /geodata/eudem_dem_3035_europe.tif
> Driver: GTiff/GeoTIFF
> Files: /geodata/eudem_dem_3035_europe.tif
> Size is 240000, 200000
> Coordinate System is:
> PROJCS["ETRS89 / LAEA Europe",
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]],
>     AUTHORITY["EPSG","3035"]]
> Pixel Size = (25.000000000000000,-25.000000000000000)
> Previously:
> # using default GDAL cache (~40MB, which is tiny also for gdalwarp etc!)
> GRASS 7.0.0svn (eu_laea):~ > time -p r.in.gdal
> /geodata/eudem_dem_3035_europe.tif \
>   output=eudem_dem_3035_europe
>  100%
> Raster map <eudem_dem_3035_europe> created.
> r.in.gdal complete.
> real 279901.23
> user 267876.52
> sys 1456.18
> --> 77h
> New:
> # I have now defined 300MB as default cache size (i.e. memory=300)
>   output=eu_dem_25m
>  100%
> Raster map <eu_dem_25m> created.
> r.in.gdal complete.
> real 5381.95
> user 5091.27
> sys 31.03
> --> 1:30h
> The user can set different cache sizes via the memory option as
> before. Most probably didn't know about this huge difference, that's
> why I added 300MB as default cache size (rather than keeping the
> original tiny GDAL setting [1]).
> If I am not wrong, it took only 2% of the previous time for importing
> this big file.
> Perhaps the GDAL project should reconsider their default cache size as well :-)
> enjoy,
> Markus
> [1] http://trac.osgeo.org/gdal/wiki/ConfigOptions#GDAL_CACHEMAX
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
