[GRASS-dev] [GRASS GIS] #2386: wxGUI: check for old vector topology format
GRASS GIS trac at osgeo.org
Thu Jul 31 08:46:51 PDT 2014
 Reporter:  martinl      |       Owner:  grass-dev@…
     Type:  task         |      Status:  new
 Priority:  critical     |   Milestone:  7.0.0
Component:  wxGUI        |     Version:  unspecified
 Keywords:  v.build.all  |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by wenzeslaus):
 Replying to [ticket:2386 martinl]:
 > This tool would
 >  1. switch to map's mapset on background
 >  1. call `v.build` or `v.build.all`
 >  1. switch back to current mapset and re-render display
 "Switch to" and "switch back" should be done by passing `env` parameter to
 the module calling function. In this way only the subprocess has the other
 mapset environment. There is even no "switch back" except from deleting
 the GRASS `rc` file which was passed to the subprocess. See e.g. r60376.
 This is also something which could be in data catalog. However, I agree
 that the point is to have it easily accessible when the problem occurs.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2386#comment:2>
