[GRASS-dev] grass7 - python script - moving window: how to simplify/accelerate r.mapcalc?
Helmut Kudrnovsky
hellik at web.de
Sun Jun 1 01:41:12 PDT 2014
Glynn Clements wrote
> Helmut Kudrnovsky wrote:
>> to answer my own question, new lines are not recognized correctly in the
>> expression,
> I should have read your follow-up before sending my reply.
> But, for future reference, can you test the other two options (using
> CR+LF, and using write_command())?
> Glynn Clements <
> glynn at .plus
> grass-dev mailing list
> grass-dev at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Can you try replacing the grass.mapcalc() call with:
> grass.write_command('r.mapcalc', file = '-', stdin = expr)
0
=> calculation done
>Or maybe it requires CR+LF on Windows:
> expr = "calc4 = (100.0 / 48.0) * \\\r\n(%s)" % " + \\\r\n".join(terms)
> grass.mapcalc(expr)
=> wxpython GUI crash
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/grass7-python-script-moving-window-how-to-simplify-accelerate-r-mapcalc-tp5143161p5143452.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
