[GRASS-dev] [GRASS GIS] #2314: output r.out.xyz
GRASS GIS trac at osgeo.org
Sun Jun 1 06:05:09 PDT 2014
 Reporter:  pvanbosgeo                           |       Owner:  grass-dev@…
     Type:  defect                               |      Status:  new
 Priority:  normal                               |   Milestone:  7.0.0
Component:  Default                              |     Version:  svn-trunk
 Keywords:  separator, pipe, r.out.xyz, r.stats  |    Platform:  MSWindows 7
      Cpu:  All                                  |
Comment(by hcho):
 Replying to [comment:25 glynn]:
 > Replying to [comment:18 annakrat]:
 > > > If a command is executed via e.g. grass.run_command(), Python's
 subprocess.Popen() provides the necessary quoting.
 > > Apparently not.
 > Er, sort of. It quotes it, but the shell interprets | (and < and >) even
 when quoted.
 Quoting didn't help. I had to escape special characters with {{{^^^}}} in
 r60634. It looks like subprocess.Popen(shell=True) calls cmd.exe twice, so
 double escaping was needed. E.g., to escape {{{|}}}, {{{^^^|}}}} needs to
 be fed into cmd.exe, but since cmd.exe is called twice, three {{{^}}}
 becomes six {{{^}}} and {{{|}}} becomes {{{^|}}}. So we need
 {{{^^^^^^^|}}}. I tested r60634 on Windows 7 with trunk and it worked.
 Now back to G_OPT_F_SEP, since we fixed {{{|}}}, showing {{{|}}} or pipe
 as default is a preference only.
 Regarding the backtick issue, it was not exactly an issue because cmd.exe
 does not support backticks anyway. I talked about g.mlist output=, which
 was implemented recently. There was no way to support backticks, so we had
 to implement output=.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2314#comment:26>
