[GRASS-dev] [GRASS GIS] #2314: output r.out.xyz
trac at osgeo.org
Sun Jun 1 10:02:35 PDT 2014
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: separator, pipe, r.out.xyz, r.stats | Platform: MSWindows 7
Cpu: All |
Comment(by neteler):
Replying to [comment:24 glynn]:
> Replying to [comment:17 hcho]:
> > The backtick issue was worked around because it couldn't be fixed (?)
in Windows.
> "Bactick issue"? Can you elaborate?
> Backticks are a shell construct, so they shouldn't be applicable to
GRASS 7, where use of the shell should have been almost entirely
eliminated.
For a (solved) issue, see ticket #1724.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2314#comment:28>
