[GRASS-dev] g.mlist list multiple types from all mapsets
Huidae Cho grass4u at gmail.com
Tue Jun 3 00:43:01 PDT 2014
I tested g.mlist with the attached script. I started from test_g_list.py
and replaced g.list with g.mlist -p and g.list -f with g.mlist -f. g.mlist
passed the test, which means g.list == g.mlist -p & g.list -f == g.mlist -f.
g.mlist does everything g.list does and provides more functionalities, so
do we want to retire the old g.list and replace it with g.mlist?
On Fri, May 30, 2014 at 9:35 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi,
> I don't think that there will be any issue but to introduce the idea how
> testing can be used, I added a test of the most essential functionality of
> g.list. Once g.list is replaced by g.mlist, the test can be used to ensure
> that old g.list functionality works as expected. (In fact I used g.mlist
> output as a reference in test, so it is already tested.)
> This is more a proof of concept but it serves its purpose at the same
> time. Feel free to comment or try to add your tests. You don't have to
> bother with things like a location etc. Just expect that you are in a
> (empty) user1 mapset of nc_smp location and run the tests there (not in
> your precious production location). In the future, these things will be
> hopefully managed by the testing framework. You can even write in bash if
> you have ideas what or how to test (it will be converted to Python later).
> Vaclav
> http://trac.osgeo.org/grass/browser/grass/trunk/general/g.list/test_g_list.py?rev=60619
> On Thu, May 29, 2014 at 5:08 AM, Luca Delucchi <lucadeluge at gmail.com>
> wrote:
>> On 28 May 2014 15:21, Martin Landa <landa.martin at gmail.com> wrote:
>> > Hi,
>> Hi
>> > 2014-05-28 15:07 GMT+02:00 Huidae Cho <grass4u at gmail.com>:
>> >> Looks great! Personally I don't see a reason to have two versions of
>> >> list/remove. Time to replace the old g.list,remove with the g.m*
>> version?
>> > personally I agree, if we decide to do that, it should be done ASAP
>> > (testing in trunk, backport to relbr70).
>> me too
>> > Martin
>> ciao
>> Luca
>> http://gis.cri.fmach.it/delucchi/
>> www.lucadelu.org
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140603/9dac8780/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140603/9dac8780/attachment-0001.obj>
