[GRASS-dev] [GRASS GIS] #2324: v.to.rast: useless area warning on points-only maps
GRASS GIS trac at osgeo.org
Tue Jun 3 08:12:57 PDT 2014
 Reporter:  neteler      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Vector       |     Version:  svn-releasebranch70
 Keywords:  v.to.rast    |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by hcho):
 IMO, type=point,line,area means to select those types only if they are
 valid type in the input map. If a map is point only, type=line,area should
 be ignored and no warnings about areas should be printed.
 int sort_areas(...)
     nareas = Vect_get_num_areas(Map);
     if (nareas == 0)
         return -1;
 int vect_to_rast(...)
     if (use != USE_Z && use != USE_D && (ftype & GV_AREA)) {
         if ((nareas = sort_areas(&Map, Points, field, cat_list)) >= 0) {
             if (nareas == 0)
                 G_warning(_("No areas selected from vector map <%s>"),
                           vector_map);
             G_debug(1, "%d areas sorted", nareas);
         } /* else map with no areas */
Ticket URL: <http://trac.osgeo.org/grass/ticket/2324#comment:2>
