[GRASS-dev] the function of v.buffer `minordistance' option
Maciej Sieczka
msieczka at sieczka.org
Wed Jun 4 11:42:01 PDT 2014
W dniu 04.06.2014 14:53, Moritz Lennert pisze:
> On 03/06/14 19:59, Maciej Sieczka wrote:
>> Anybody knows what is the v.buffer's `minordistance' option supposed
>> to do?
>> The manual is not verbose about that, but as I understand it, together
>> with `distance', it should allow to create a buffer with different
>> extent along the minor and major axis, considering the specified `angle'
>> of their rotation.
>> But none of the options works as that - the buffer size always equals
>> the `distance', and the other 2 options make no difference if used or
>> not an set to what.
>> BTW, it seems that -s, -c flags also don't have any effect on the output.
>> Did I get it wrong or maybe there's something broken?
> In NC dataset:
> v.buffer schools_wake out=testbuf distance=500 minordistance=250
> gives me the attached buffers. Everything seems to work fine here...
> Could you be more specific about what exactly is not working for you ?
Right, looks fine for points input. Not so for areas input though, e.g:
$ v.buffer testbuf out=testbuf2 distance=500 minordistance=250
v.buffer in the latter case does not honor minordistance and uses
distance for both axes, while I would expect it to behave the way it
does for points input. Am I expecting something which is not implemented
maybe?
Maciek
Maciej Sieczka
http://www.sieczka.org
