[GRASS-dev] [GRASS-SVN] r60679 - grass/trunk/lib/python/script
Markus Neteler
neteler at osgeo.org
Wed Jun 4 13:35:48 PDT 2014
On Wed, Jun 4, 2014 at 7:56 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
> So either:
> 1. GRASS 7 will need .bat wrappers for Python scripts on Windows. That
> has the same issues as using shell=True, but at least it only applies
> in the case where we're executing a script.
... this would follow the apparently working method in GRASS 6.
Maybe worth a try also in GRASS 7 at this point.
> 2. If we know that the "program" is a script, the interpreter can be
> specified explicitly (i.e. "python path/to/script.py"). This keeps the
> shell out of the picture.
... how much effort is the latter? Check file type and path to file?
Markus
