[GRASS-dev] os.environ['GRASS_REGION'] Error
Javier Martínez-López javi.martinez.lopez at gmail.com
Thu Jun 5 01:27:54 PDT 2014
Hello all,
trying to create a temporary region within a python GRASS script using:
os.environ['GRASS_REGION'] = grass.region_env(res=150)
I get the following errors on a CentOS server:
ERROR: Syntax error in cell header
ERROR: Field <projection> missing
GRASS version:
GRASS 7.1.svn (2014)
libgis Revision: 60707
libgis Date: 2014-06-05 00:58:35 +0200 (Thu, 05 Jun 2014)
Doing it on my Ubuntu installation works fine! Any idea about what
could be the problem?
Thank you very much!
Cheers,
Javier
