[GRASS-dev] [GRASS GIS] #2326: Command functions in grass.script.core miss a correct error reporting
trac at osgeo.org
Fri Jun 6 00:24:18 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Keywords: script | Platform: All
Cpu: Unspecified |
Comment(by glynn):
Replying to [ticket:2326 wenzeslaus]:
> The later is actually a motivation for this ticket because I see this as
a critical issue which is very dangerous for
[https://gis.stackexchange.com/questions/99773/problems-running-grass-
mapcalc/ beginners] (writing scripts with `run_command` or others) and not
checking the return code or stderr with an expectation that the function
will report the error (in Python sense, thus raising an exception).
Personally, I'd suggest just modifying the existing functions to raise
exceptions if the command fails.
Scripts which want to do their own error handling can just use
start_command() directly; the higher-level functions are only trivial
wrappers around this.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2326#comment:1>
