[GRASS-dev] [GRASS GIS] #2258: t.create creates DB always in the PERMANENT
trac at osgeo.org
Fri Jun 6 15:42:56 PDT 2014
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Temporal | Version: svn-releasebranch70
Keywords: t.register | Platform: Unspecified
Cpu: Unspecified |
Comment(by huhabla):
Replying to [comment:7 neteler]:
> Replying to [comment:5 huhabla]:
> > Replying to [comment:4 glynn]:
> > > Replying to [comment:3 huhabla]:
> > > > There is a reason why the temporal database is generated and used
by default in the PERMANENT directory.
> > > Does it handle the case where the user lacks the filesystem
permissions to write to PERMANENT?
> > There is no explicit error handling implemented. The creation process
will terminate with a Python exception.
> Here in our shared /network and multi-user grassdata/ we have exactly
this problem:
> while I am the PERMANENT owner, my colleague cannot write into the DB.
> As a compromise, t.create should advertise t.connnect as a solution to
the problem, otherwise
> users get immediately stuck.
Please try r60732, i have improved the error messages in case the database
creation or access fails. Database connection failures will now result in
a fatal error rather then Python traceback.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2258#comment:8>
