[GRASS-dev] g.mlist list multiple types from all mapsets
Huidae Cho
grass4u at gmail.com
Sun Jun 8 04:10:28 PDT 2014
Non-existent mapset fixed in r60749.
Multiple mapsets is not too much, but do we need it? Also, if we implement
multiple mapsets, it would be better semantically to change "mapset=.." to
"mapset=*" for all mapsets in the current location. Martin, do you mind if
I change mapset=.. to mapset=*?
On Fri, Jun 6, 2014 at 12:18 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Tue, Jun 3, 2014 at 3:43 AM, Huidae Cho <grass4u at gmail.com> wrote:
>> I tested g.mlist with the attached script. I started from test_g_list.py
>> and replaced g.list with g.mlist -p and g.list -f with g.mlist -f. g.
>> mlist passed the test, which means g.list == g.mlist -p & g.list -f == g.
>> mlist -f.
> More tests needed. g.mlist does not complain about not existing mapset:
> $ g.mlist pattern="lsat*" type=rast mapset=xxxxxx
> [no output]
> $ echo $?
> 0
> By the way, is multiple for mapset a planned feature? Or it is too much?
> Pattern for mapset seems too much for sure.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140608/b65fa6d3/attachment-0001.html>
