[GRASS-dev] g.mlist list multiple types from all mapsets
Vaclav Petras
wenzeslaus at gmail.com
Sun Jun 8 05:30:16 PDT 2014
On Sun, Jun 8, 2014 at 7:10 AM, Huidae Cho <grass4u at gmail.com> wrote:
> Non-existent mapset fixed in r60749.
> Thanks. I can confirm that it works. Now we need the test for it.
On Fri, Jun 6, 2014 at 12:18 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> By the way, is multiple for mapset a planned feature? Or it is too much?
> Pattern for mapset seems too much for sure.
> Multiple mapsets is not too much, but do we need it?
I don't know. I asked because I just automatically tried that syntax
because I used `pattern="something,some_*"` syntax recently.
> Also, if we implement multiple mapsets, it would be better semantically to
> change "mapset=.." to "mapset=*" for all mapsets in the current location.
> Martin, do you mind if I change mapset=.. to mapset=*?
> I would say that in any case, * fits more with the other options, although
* is also used also for null values (besides nv and others).
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140608/3fdf6274/attachment.html>
