[GRASS-dev] [GRASS-SVN] r60747 - grass/branches/releasebranch_7_0/vector/v.in.ogr
Huidae Cho grass4u at gmail.com
Sun Jun 8 16:59:20 PDT 2014
I didn't check the 6 code, but if it has the same code, I think yes.
On Jun 8, 2014 3:12 PM, "Markus Neteler" <neteler at osgeo.org> wrote:
> Hi,
> On Sun, Jun 8, 2014 at 11:59 AM,  <svn_grass at osgeo.org> wrote:
> > Author: hcho
> > Date: 2014-06-08 02:59:35 -0700 (Sun, 08 Jun 2014)
> > New Revision: 60747
> > Modified:
> >    grass/branches/releasebranch_7_0/vector/v.in.ogr/main.c
> > Log:
> > v.in.ogr: ymax fixed (merge from r60656)
> > Modified: grass/branches/releasebranch_7_0/vector/v.in.ogr/main.c
> > --- grass/branches/releasebranch_7_0/vector/v.in.ogr/main.c
> 2014-06-08 09:44:57 UTC (rev 60746)
> > +++ grass/branches/releasebranch_7_0/vector/v.in.ogr/main.c
> 2014-06-08 09:59:35 UTC (rev 60747)
> > @@ -1412,9 +1412,9 @@
> >             else
> >                 xmax = abs(box.W);
> >             if (abs(box.N) > abs(box.S))
> > -               xmax = abs(box.N);
> > +               ymax = abs(box.N);
> >             else
> > -               xmax = abs(box.S);
> > +               ymax = abs(box.S);
> >             if (xmax < ymax)
> >                 xmax = ymax;
> I suppose that this should also be backported to GRASS 6?
> (I can do that)
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140608/91eaa824/attachment.html>
