[GRASS-dev] [GRASS GIS] #2334: configure --without-curses not honoured
trac at osgeo.org
Sat Jun 14 03:08:29 PDT 2014
Reporter: strk | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Compiling | Version: 6.4.3
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:2 neteler]:
> libncurses4.x/5.x is a requirement for GRASS GIS 6:
Sort of. If you build without curses, most of GRASS will still be built.
While the end result is rather "rough", it may well be sufficient for some
people. But where it fails, it won't fail particularly gracefully (some
parts of GRASS simply assume that certain modules will exist, and with
curses disabled, they won't).
Building GRASS 6.x without curses support is sufficiently uncommon that it
isn't worth the (significant) effort of "polishing". --without-curses was
added so that people who could live with the end result had that option,
rather than simply having the configure script fail.
This doesn't apply to GRASS 7, where curses support has been removed
entirely (no configure checks, modules which use curses have been re-
written, disabled, or removed).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2334#comment:4>
