[GRASS-dev] [GRASS GIS] #2326: Command functions in grass.script.core miss a correct error reporting
trac at osgeo.org
Sat Jun 14 23:07:06 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: major | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Keywords: script, exceptions | Platform: All
Cpu: Unspecified |
Changes (by wenzeslaus):
* keywords: script => script, exceptions
Comment:
Here are my suggestions for changes in `grass.script.core`.
The `read_command` function is similar to
[https://docs.python.org/2/library/subprocess.html#subprocess.check_output
subprocess.check_output] function, so I used the implementation from
Python subprocess
([http://hg.python.org/cpython/file/2145593d108d/Lib/subprocess.py#l508
cpython: Lib/subprocess.py]). It check the `stderr` parameter, uses
`communicate()` and `poll()` and raises on non-zero return code. The main
difference from `subprocess.check_output` (expect from GRASS parameter
handing) is that stderr is stored to exception to provide a detailed
message at the right place.
#!python
def read_command(*args, **kwargs):
"""Run command and return its output."""
# implemenation inspired by subprocess.check_output() function
if 'stderr' in kwargs:
raise ValueError('stderr argument not allowed, it would be
overridden.')
kwargs['stderr'] = PIPE
process = pipe_command(*args, **kwargs)
output, errors = process.communicate()
returncode = process.poll()
if returncode:
cmd = kwargs.get("args")
if cmd is None:
cmd = args[0]
raise CalledCommandError(returncode, cmd, errors=errors)
return output
Note that `read_command()` is used by `parse_command()` function and that
`pipe_command()` might be replaced by `start_command()` and `stdout=PIPE`.
`write_command()` is similar to `read_command()` but without stdin and win
stdout as a string:
#!python
def write_command(*args, **kwargs):
"""!Passes all arguments to feed_command, with the string specified
by the 'stdin' argument fed to the process' stdin.
if 'stdin' not in kwargs:
raise ValueError('stdin argument is required.')
overridden.')
stdin = kwargs['stdin'] # get a string for stdin
kwargs['stdin'] = PIPE # to be able to send data to stdin
process = start_command(*args, **kwargs)
unused, errors = process.communicate(stdin)
if returncode:
if cmd is None:
cmd = args[0]
raise CalledCommandError(returncode, cmd, erros=errors)
# subprocess.check_call() function returns 0 for success
# but this would create only confusion since we don't return for
failure
`write_read_command()` is a new proposed function which is a combination
of `write_command()` and `read_command()` functions.
#!python
def write_read_command(*args, **kwargs):
"""Uses stdin string as stdin and returns stdout"""
if 'stdout' in kwargs:
raise ValueError('stdout argument not allowed, it would be
overridden.')
overridden.')
kwargs['stdout'] = PIPE
output, errors = process.communicate(stdin)
if returncode:
if cmd is None:
cmd = args[0]
return output
I'm not sure with limitations of `write_command()`, `read_command()` and
`write_read_command()` considering large inputs and outputs but they are
using `out, err = p.communicate(stdin)` and `p.poll()` which should be the
best way according to what Glynn is saying, library (subprocess) is using,
and documentation is suggesting. Moreover, they are not worse that the
existing functions and I expect that for special cases you need to use
`start_command()` directly anyway.
The missing function is now a function which would [comment:3 connect
stdout and stderr] (`stdout=PIPE, stderr=STDOUT`). But this is again
something special (e.g. used in GUI) which might not need a convenient
function and user should use `start_command()` directly.
Considering how `run_command()` function is used I would suggest to change
it to raise an exception. This will break the code which was using it
correctly and this code will have to be fixed manually and perhaps adding
try-except will be necessary. However, most of the code will improve since
it will at least fail with proper error message at proper place and not
few lines further with hard-to-understand message. Adding `return 0` to
the end of the function may provide a compatibility with previous behavior
for cases when the return value was used. It will not create an error when
everything is OK but it will not use the error handling at that place when
the command fails. At the end, `return 0` should be removed anyway.
#!diff
- ps = start_command(*args, **kwargs)
- return ps.wait()
+ if 'stdin' not in kwargs:
+ raise ValueError('stdin argument is required.')
+ else:
+ stdin = kwargs['stdin']
+ del kwargs['stdin'] # clean non-standard argument
+ process = feed_command(*args, **kwargs)
+ unused, errors = process.communicate(stdin)
+ returncode = process.poll()
+ if returncode:
+ cmd = kwargs.get("args")
+ if cmd is None:
+ cmd = args[0]
+ raise CalledCommandError(returncode, cmd, erros=errors)
+ return 0
I don't see particular advantage in functions `pipe_command()` (sets
`kwargs['stdout'] = PIPE`) and `feed_command()` (sets `kwargs['stdin'] =
PIPE`). The the parameters can be set directly with the function
`start_command()` and for me the functions does not contribute to
readability because the ''feed'' does not tell me if the string is the
input (as for `write_command()` function) or it justs sets `stdin=PIPE`.
Similarly, ''pipe'' does not tell me if everything is piped (stdin, stdout
and stderr), stdin and stdout are piped (as for `write_read_command()`
function) or just one of stdin and stdout is piped. It is even more
confusing name when I consider piping in command line where I connect
multiple processes (which is not done by PIPE constant in
[https://docs.python.org/2/library/subprocess.html#replacing-shell-
pipeline subprocess]).
I wanted to change (instead of adding) the functions, especially
`run_command()`, originally but then I was afraid of problems with
releasing 7.0 and changing API. However, the usage statistics and the fact
that Glynn [comment:1 suggested the same] convinced me that we should
really do it. However, it is challenging, we have to change some code (at
least 150 occurrences of `run_command()` and `write_command()` in trunk
and addons but maybe also other functions) and I'm still not sure with
some detail such as if stderr should be always captured to get the right
error message (consider e.g. the result with `DEBUG=1`).
Another consideration is raising exception versus calling `fatal()`
function which can be set to raise exception but this exception would have
to contain everything in a message while a custom exception (I used one
derived from
[https://docs.python.org/2/library/subprocess.html#subprocess.CalledProcessError
subprocess.CalledProcessError]) can store return code, command (or
command/module name) and stderr separately.
For the 7.0 this actually should not be applied completely but the API
should be changed to fit the improved implementation/new API, so
`run_command()` function should have `return 0` but a waring in
documentation. Then perhaps `pipe_command()` and `feed_command()`
functions should be marked as depreciated.
Adding (not tested) draft of proposed changes.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2326#comment:6>
