[GRASS-dev] [GRASS GIS] #2333: choose python interpreter during the GRASS installation on windows
trac at osgeo.org
Mon Jun 16 10:34:17 PDT 2014
Reporter: zarch | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Keywords: windows installer python interpreter | Platform: MSWindows 8
Cpu: All |
Comment(by hellik):
Replying to [comment:12 zarch]:
> Replying to [comment:11 hellik]:
> > Replying to [comment:10 zarch]:
> > > ok, next week I will try to look in to the nsis script to see if
> > > it is possible to add this option during the installation process.
> > some steps may be:
> > - add e new installer gui-section "Customize python" (or something
like that)
> > - add some explanations to the gui-section "Customize python": e.g.
compatible wxpython, numpy, matplotlib, etc. are needed, ...
> > - default option: %GRASS_PYTHON% is the packaged python
> > - user option: ask the user for the %PATH% to the user wanted python
> [[BR]]
> Thank you Helmut for your help.
> I'm not sure If I understood how to add a new section, I wrote:
> Section "Customize python" CustomizePython
> ;Declares variables for optional Python interpreter
> Var /GLOBAL PYINTERPRETER
> Var /GLOBAL PYHOME
> ;Set default values for the Python Interpreter
> ${If} $ASK_FOR_PYINTERP == "NO"
> StrCpy $PYINTERPRETER "%GISBASE%\extrabin\python.exe"
> ${Else}
> StrCpy $PYINTERPRETER "$INST_PYINTERP"
> ${EndIf}
> ;Set default values for the Python home folder
> ${If} $ASK_FOR_PYHOME == "NO"
> StrCpy $PYHOME "%GISBASE%\Python27"
> ${Else}
> StrCpy $PYHOME "$INST_PYHOME"
> ${EndIf}
> ;Create the etc\env.bat
> ClearErrors
> FileOpen $0 $INSTALL_DIR\etc\env.bat w
> IfErrors done_create_grass_environments.bat
> FileWrite $0 '@echo off$\r$\n'
> FileWrite $0 'rem
#########################################################################$\r$\n'
> FileWrite $0 'rem #$\r$\n'
> FileWrite $0 'rem # File dynamically created by NSIS installer
script;$\r$\n'
> FileWrite $0 'rem
> FileWrite $0 'rem # Environmental variables for GRASS stand-alone
installer$\r$\n'
> FileWrite $0 'rem
> FileWrite $0 '$\r$\n'
> FileWrite $0 'set GRASS_SH=%GISBASE%\msys\bin\sh.exe$\r$\n'
> FileWrite $0 'set GRASS_HTML_BROWSER=explorer"$\r$\n'
> FileWrite $0 'set GRASS_PYTHON=$PYINTERPRETER$\r$\n'
> FileWrite $0 'set PYTHONHOME=$PYHOME$\r$\n'
> FileWrite $0 'set GRASS_PROJSHARE=%GISBASE%\share\proj$\r$\n'
> FileWrite $0 'set PROJ_LIB=%GISBASE%\share\proj$\r$\n'
> FileWrite $0 'set GDAL_DATA=%GISBASE%\share\gdal$\r$\n'
> FileWrite $0 'set GEOTIFF_CSV=%GISBASE%\share\epsg_csv$\r$\n'
> FileWrite $0 'set PATH=%GISBASE%\msys\bin;%PATH%$\r$\n'
> FileWrite $0 'set PATH=%GISBASE%\extrabin;%PATH%$\r$\n'
> FileWrite $0 'set PATH=%GISBASE%\bin;%PATH%$\r$\n'
> FileClose $0
> SectionEnd
> Do you see any better way to implement this, avoiding to generate the
env.bat file?
> How can I define as optional to set the path to the python interpreter
and to the python home in the GUI?
> Where should I add the description with the python requirements (numpy,
wxpython, etc)?
> There is a way to view/test the modified NSIS file?
Hi Pietro,
I'm travelling, no chance to look at it at the moment.
there is no need to write a new env.bat file, just replace the path string
in the existing env.bat.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/2333#comment:18>
