[GRASS-dev] [GRASS GIS] #2333: choose python interpreter during the GRASS installation on windows
trac at osgeo.org
Tue Jun 17 04:43:23 PDT 2014
Reporter: zarch | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Keywords: windows installer python interpreter | Platform: MSWindows 8
Cpu: All |
Comment(by martinl):
Replying to [comment:19 glynn]:
> So, do we mimic the shell (locate the program and determine its suffix),
or use it (and
There was something similar installed for Python scripts (1). One option
would be to load all commands to an internal directory (similarly to
wxGUI) when loading python script library
{ 'bat': [], 'exe': ['g.parser', ...] }
rather then determining it's suffix for every command separately.
> I still don't consider the previous approach (use the shell, don't
bother escaping anything) to be a viable solution.
Using `shell=True` seems to be less problematic to me, is it problem to
determine escaping rules for special characters (I know only about pipe
problem till now).
(1)
http://trac.osgeo.org/grass/changeset/60679/grass/trunk/lib/python/script/core.py
(L56)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2333#comment:20>
