[GRASS-dev] [GRASS GIS] #2343: GRASS 7: "inf" values break insert statements in v.rast.stats
GRASS GIS trac at osgeo.org
Thu Jun 19 04:36:55 PDT 2014
 Reporter:  sbl           |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  normal        |   Milestone:  7.0.0
Component:  Python        |     Version:  svn-releasebranch70
 Keywords:  v.rast.stats  |    Platform:  All
      Cpu:  All           |
Comment(by glynn):
 Replying to [ticket:2343 sbl]:
 > "inf" breaks the INSERT statement and results in an DBMI error "no such
 column: inf", which at the end crashes v.rast.stats.
 > Just like "nan", "inf" could be replaced by NULL.
 FWIW, PostgreSQL supports infinity and NaN values, e.g.
 CREATE TABLE test ( value REAL ) ;
 INSERT INTO test VALUES (REAL 'Infinity');
 INSERT INTO test VALUES (REAL '+Infinity');
 INSERT INTO test VALUES (REAL '-Infinity');
 INSERT INTO test VALUES (REAL 'NaN');
 SELECT * FROM test ;
    value
   Infinity
   Infinity
  -Infinity
        NaN
 (4 rows)
 I don't know whether this is part of the SQL standard, or whether it is
 supported by the other back-ends. It won't work for columns of type
 NUMERIC.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2343#comment:2>
