[GRASS-dev] [GRASS-SVN] r60855 - grass/branches/releasebranch_7_0/raster/r.watershed/front
Markus Neteler
neteler at osgeo.org
Thu Jun 19 11:33:05 PDT 2014
Hi Huidae,
Markus Metz is the expert here...
Best
MarkusN (just doing a lot of backporting)
On Thu, Jun 19, 2014 at 8:21 PM, Huidae Cho <grass4u at gmail.com> wrote:
> Hi Markus,
> Is sink filling discouraged or just not needed and optional? My impression
> is that r.watershed produces better results with not sink filled rasters,
> but sink filling doesn't hurt much.
> Thanks.
> Huidae
> On Tue, Jun 17, 2014 at 1:40 PM, <svn_grass at osgeo.org> wrote:
>> Author: neteler
>> Date: 2014-06-17 10:40:00 -0700 (Tue, 17 Jun 2014)
>> New Revision: 60855
>> Modified:
>> grass/branches/releasebranch_7_0/raster/r.watershed/front/r.watershed.html
>> Log:
>> r.watershed manual: (minor) sync with trunk
>> Modified:
>> 2014-06-17 17:39:37 UTC (rev 60854)
>> 2014-06-17 17:40:00 UTC (rev 60855)
>> @@ -55,7 +55,8 @@
>> values are valid elevation data. Gaps in the elevation map that are
>> located within the area of interest must be filled beforehand,
>> e.g. with <em><a href="r.fillnulls.html">r.fillnulls</a></em>, to
>> -avoid distortions.
>> +avoid distortions. The elevation map need not be sink-filled because
>> +the module uses a least-cost algorithm.
>> <p>
>> Map of actual depressions or sinkholes in the landscape that are large
>> @@ -113,7 +114,7 @@
>> <p>
>> Output <b>tci</b> raster map contains topographic index TCI is
>> computed as
>> -<tt>ln(α / tan(β))</tt> where α a is the cumulative
>> +<tt>ln(α / tan(β))</tt> where α is the cumulative
>> upslope area draining through a point per unit contour length and
>> <tt>tan(β)</tt> is the local slope angle. The TCI reflects the
>> tendency of water to accumulate at any point in the catchment and the
>> grass-commit mailing list
>> grass-commit at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-commit
