[GRASS-dev] g.mlist list multiple types from all mapsets
Fri Jun 20 17:38:43 PDT 2014
Huidae Cho wrote:
> Hmm... one flag -s (switch default) should be enough, I think.
I think not. We need a way to specify a particular output format. A
"switch" flag is only useful if you already know which format will be
used without that flag, which isn't necessarily straightforward.
A similar issue arose for r.{in,out}.bin.
They used to have a -b (byte-swap) flag (it's actually still there,
for compatibility).
This is fine for interactive use, where the user (hopefully) knows
whether the byte-order of the platform they're using matches that of
the data.
But a script which is intended to be portable would have to first
determine the byte order of the platform then either use or omit the
-b flag depending on the result.
The current versions have an order= option (values: big, little,
native, swap), so that a script can simply use order=big or
order=little, and not have to work out whether that means
byte-swapping or not.
