[GRASS-dev] [GRASS GIS] #2136: Create standard options for map or file base name (prefix)
GRASS GIS trac at osgeo.org
Mon Jun 23 06:33:02 PDT 2014
 Reporter:  wenzeslaus                   |       Owner:  grass-dev@…
     Type:  defect                       |      Status:  new
 Priority:  normal                       |   Milestone:  7.0.0
Component:  Parser                       |     Version:  svn-releasebranch64
 Keywords:  base name, prefix, basename  |    Platform:  All
      Cpu:  All                          |
Comment(by zarch):
 The list of the modules using the word "prefix" as name of the parameter
 or in the parameter description is (module name => parameter name,
 parameter description):
     - g.extension => prefix: Prefix where to install extension (ignored
 when flag -s is given)
     - i.cca => output: Output raster map prefix name
     - i.landsat.acca => input_prefix: Example: 'B.' for B.1, B.2, ...
     - i.landsat.toar => input_prefix: Example: 'B.' for B.1, B.2, ...
     - i.landsat.toar => output_prefix: Example: 'B.toar.' generates
 B.toar.1, B.toar.2, ...
     - i.pansharpen => output_prefix: Prefix for output raster maps
     - i.pca => output_prefix: A numerical suffix will be added for each
 component map
     - i.tasscap => output_prefix: Prefix for output raster maps
     - i.topo.corr => output: Name (flag -i) or prefix for output raster
 maps
     - m.nviz.script => name: Prefix of output images (default = NVIZ)
     - r.blend => output_prefix: Prefix for red, green and blue output
 raster maps containing
     - r.rgb => output_prefix: Prefix for output raster maps (default:
 input)
     - r.ros => output: Prefix for output raster maps (.base, .max,
 .maxdir, .spotdist)
     - r.texture => prefix: Prefix for output raster map(s)
     - v.out.postgis => dsn: Starts with 'PG' prefix, eg. 'PG:dbname=grass'
     - v.rast.stats => column_prefix: Column prefix for new attribute
 columns
 Just for the record I attached the code to look for a word in all the
 GRASS modules:
 #!python
 from __future__ import print_function
 import sys
 from grass.pygrass.modules.shortcuts import (display, database, general,
                                              imagery, miscellaneous,
                                              postscript, raster, raster3D,
                                              temporal, vector)
 mods = [display, database, general, imagery, miscellaneous, postscript,
         raster, raster3D, temporal, vector]
 SKIP = ['v.pack', 'v.parallel']
 def look(modules, word, skip, file=sys.stdout):
     mlen = len(modules.__dir__())
     for i, module in enumerate(modules.__dir__()):
         try:
             md = "%s.%s" % (modules.prefix, module)
             print("%03d/%03d - %s" % (i + 1, mlen, md))
             if md in skip:
                 print("SKIPED: %s" % md)
             else:
                 m = getattr(modules, module)
                 for p in m.params_list:
                     if ((p.name is not None and word in p.name.lower()) or
                             (p.description is not None and
                              word in p.description.lower())):
                         print("%s => %s, %s" % (m.name, p.name,
 p.description),
                               file=file)
                 del(m)
         except:
             print("Not able to read: %s.%s" % (modules.prefix, module),
                   file=file)
             #import ipdb; ipdb.set_trace()
     del(modules)
 with open("prefix.txt", "w") as file:
     for m in mods:
         look(m, "prefix", skip=SKIP, file=file)
 In this way I found out that pygrass modules interface crashed with these
 two modules:
     - v.pack
     - v.parallel
 and raise an exception trying to read:
     - g.parser
     - i.eb_h_sebal01
     - t.rast_accdetect
     - t.rast_accumulate
     - t.rast_aggregate
     - t.rast_aggregate_ds
     - t.rast_extract
     - t.rast_gapfill
     - t.rast_import
     - t.rast_mapcalc
     - t.rast_neighbors
     - t.rast3d_mapcalc
     - t.vect_extract
     - v.generalize
 So I will look into it during the next days.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2136#comment:5>
