[GRASS-dev] [GRASS GIS] #2136: Create standard options for map or file base name (prefix)
trac at osgeo.org
Tue Jun 24 08:12:15 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Parser | Version: svn-releasebranch64
Keywords: base name, prefix, basename | Platform: All
Cpu: All |
Comment(by wenzeslaus):
Replying to [comment:6 annakrat]:
> Replying to [comment:4 zarch]:
> > Replying to [comment:2 wenzeslaus]:
> > > Moreover, documentation to the standard option would
> > > define if underscore, dot or nothing is used to separate
> > > basename/prefix from the suffix/result name. So, user
> > > would know what to expect and programmer what to implement.
> > What do you think if we use two underscore (`__`) to join the basename
with the rest?
> > basename`__`01, basename`__`02, etc.
> #!python
> >>> import re
> >>> m = re.match("^(?P<name>[a-zA-Z0-9]+)__(?P<id>\w+)$",
"horizon__000")
> >>> m.groups()
> ('horizon', '000')
> >>> m.groupdict()
> {'id': '000', 'name': 'pippo'}
"tile__000_001")
> >>> m.groups()
> ('tile', '000_001')
> >>> m.groupdict()
> {'name': 'tile', 'id': '000_001'}
> > So maybe in the future the GUI would be able to group maps following
the rule "basename`__`*" and visualize them in the wxGUI Animation or
something else...
> I agree with double underscore.
I'm not sure about double underscore. I don't like how it looks like. I'm
afraid if it will be understandable for users, for example when visualized
in some GUI, you don't know how the font will show it (with mono spaced
font, you can see two underscores even if they are connected with each
other, with other fonts, you don't know). Moreover, so systems can try to
interpret the double underscore too (see what Trac did to commit message
in r60944).
On the other hand, I see the advantages too. It is much harder or more
fragile to achieve the same with one underscore (or other character).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2136#comment:8>
