[GRASS-dev] [GRASS GIS] #1452: wx location wizard doesn't ask for datum transform options because proj4 4.7.1's epsg file is broken
GRASS GIS trac at osgeo.org
Wed Jun 25 01:31:36 PDT 2014
  Reporter:  hamish              |       Owner:  hamish
      Type:  defect              |      Status:  closed
  Priority:  major               |   Milestone:  6.4.4
 Component:  Projections/Datums  |     Version:  svn-releasebranch64
Resolution:  fixed               |    Keywords:  location wizard, g.proj
  Platform:  All                 |         Cpu:  All
Changes (by hamish):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 hopefully it's all ok now. fwiw this was around for a while without a lot
 of complaints, since it was failing silently unless you were an expert in
 knowing what the projection settings output should be, and checked them.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1452#comment:47>
