[GRASS-dev] [GRASS GIS] #2340: Rename i.landsat.rgb
trac at osgeo.org
Wed Jun 25 01:37:43 PDT 2014
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Imagery | Version: svn-trunk
Keywords: i.landsat.rgb | Platform: All
Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:1 neteler]:
> more suggestions:
> * i.enhance?
> * i.colors.enhance? # may be confused with r.colors
I like i.colors.enhance: it's clear about what it does. I don't really see
the danger of confusing with r.colors. And it leaves the door open for
adding other color enhancement methods into the script (like i.pansharpen
for fusion).
BTW: the man page says "It will work with any 8-bit RGB imagery set and
the script is easily modified to work with other datasets of greater band-
depth." Is the 8-bit limit still the case ? And if yes, if it is easy to
do, why not modify it to accept greater depths ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/2340#comment:2>
