[GRASS-dev] G7: OGSF compilation error on Ubuntu 14.04
Vaclav Petras wenzeslaus at gmail.com
Wed Jun 25 08:24:29 PDT 2014
I tested compiling on Ubuntu 14.04 several times recently. Here is what is
needed.
There is already a ticket for "ogsf compilation error"
http://trac.osgeo.org/grass/ticket/2017
Where I say in the comment
--with-ffmpeg=no
http://trac.osgeo.org/grass/ticket/2017#comment:17
Perhaps, we should update "GRASS Wiki Comapile and Install Ubuntu"
accordingly.
http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu
See also recent notes on that topic in:
[GRASS-dev] Updates of wiki page for compiling on Ubuntu
http://lists.osgeo.org/pipermail/grass-dev/2014-June/069334.html
http://lists.osgeo.org/pipermail/grass-dev/2014-June/069371.html
This should help. I don't know what ffmpeg is now for.
Vaclav
On Wed, Jun 25, 2014 at 11:04 AM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> I try to help to compile 7.0 on an Ubuntu box 14.04. We fail to compile
> OGSF:
> alba at alba:~/source_code/grass70_release$ cd
> /home/alba/source_code/grass70_release/lib/ogsf
> alba at alba:~/source_code/grass70_release/lib/ogsf$ make
> gcc  -g -O2  -fPIC
> -I/home/alba/source_code/grass70_release/dist.x86_64-unknown-linux-gnu/include
>   -I/usr/include/gdal -I/usr/include  -DPACKAGE=\""grasslibs"\"
> -I/usr/include/postgresql   -I/usr/include/libavcodec
> -I/usr/include/libavformat -I/usr/include/libswscale
> -I/usr/include/libavutil
> -o OBJ.x86_64-unknown-linux-gnu/GK2.o -c GK2.c
> In file included from /usr/include/x86_64-linux-gnu/sys/stat.h:105:0,
>                  from
> /home/alba/source_code/grass70_release/dist.x86_64-unknown-linux-gnu/include/grass/defs/gis.h:64,
>                  from
> /home/alba/source_code/grass70_release/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:636,
>                  from GK2.c:21:
> /usr/include/x86_64-linux-gnu/bits/stat.h:91:21: error: field
> ‘st_atim’ has incomplete type
>      struct timespec st_atim;  /* Time of last access.  */
> /usr/include/x86_64-linux-gnu/bits/stat.h:92:21: error: field
> ‘st_mtim’ has incomplete type
>      struct timespec st_mtim;  /* Time of last modification.  */
> /usr/include/x86_64-linux-gnu/bits/stat.h:93:21: error: field
> ‘st_ctim’ has incomplete type
>      struct timespec st_ctim;  /* Time of last status change.  */
> /home/alba/source_code/grass70_release/dist.x86_64-unknown-linux-gnu/include/grass/defs/gis.h:64:0,
>                  from
>                  from GK2.c:21:
> /usr/include/x86_64-linux-gnu/sys/stat.h:365:31: error: array type has
> incomplete element type
>          const struct timespec __times[2],
> /usr/include/x86_64-linux-gnu/sys/stat.h:372:54: error: array type has
>  extern int futimens (int __fd, const struct timespec __times[2]) __THROW;
> make: *** [OBJ.x86_64-unknown-linux-gnu/GK2.o] Error 1
> Something is overriding the time definition. I found
> http://stackoverflow.com/questions/14947691/c-system-file-bits-stat-h-suddenly-breaks-with-error-field-st-atim-has-inc
> but dunno what to do next.
> Any Ubuntu user who knows the trick?
> thanks
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140625/bb059651/attachment-0001.html>
