[GRASS-dev] [GRASS GIS] #2350: G7: r.texture large file support problem
Vaclav Petras
wenzeslaus at gmail.com
Wed Jun 25 13:48:42 PDT 2014
On Wed, Jun 25, 2014 at 4:35 PM, GRASS GIS <trac at osgeo.org> wrote:
> > Is r.texture supporting LFS?
> Modules typically don't need to do anything regarding LFS; the support is
> in the libraries. The main issue which affects modules is that they
> shouldn't assume that cell counts will fit into an "int" or even a "long".
> But even failing to do so won't have any effect upon I/O.
Can you please explain what the modules are allowed to do? r.example does
not tell [1].
[1]
http://trac.osgeo.org/grass/browser/grass/trunk/doc/raster/r.example/main.c?rev=40771#L69
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140625/204d9661/attachment.html>
