[GRASS-dev] [GRASS GIS] #2229: error in projection definition
trac at osgeo.org
Wed Jun 25 22:29:40 PDT 2014
Reporter: vincent | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Projections/Datums | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Comment(by hamish):
note what shows up on the loc'n wizard summary screen is *not* the terms
used to create the location! Check your $MAPSET/PERMANENT/PROJ_INFO file
(`g.proj -p`) to see what really made it in.
vincent:
> proj4 : Rel. 4.7.1, 23 September 2009
> gdal : GDAL 1.9.0, released 2011/12/29
Debian/wheezy then? same here. the epsg file which comes with the proj-
data package there does include epsg 3857, as does wkt/csv versions of the
epsg database in grass-core, libgdal1, and libgeotiff-epsg packages. So
all is new enough.
I'm not sure how grass's /usr/lib/grass64/etc/ogr_csv/pcs.csv handles the
@null part though, or if that is even used here, it may just be the
version picked up by the OGR library functions which matters.
are you using the standard grass package from debian wheezy? (ver 6.4.2-2)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2229#comment:5>
