[GRASS-dev] [GRASS GIS] #2353: v.univar says type not supported instead of column does not exist
trac at osgeo.org
Thu Jun 26 10:09:16 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: trivial | Milestone: 7.1.0
Component: Database | Version: svn-trunk
Keywords: v.univar, vector, messages | Platform: All
Cpu: Unspecified |
G7:v.univar with column which does not exists reports low-level message
"no such column" tow times together with some other things and than gives
GRASS standard error "Column type not supported". It should end after the
first try, not print the low-level (detailed) messages (if possible,
should go to debug), and print the correct error message ""Column does not
exist" (or "not found"?).
v.univar map=bridges column='YEAR_BUILTTT'
DBMI-SQLite driver error:
Error in sqlite3_prepare():
SELECT cat, YEAR_BUILTTT FROM bridges
no such column: YEAR_BUILTTT
ERROR: Column type not supported
I was not looking to the source code.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2353>
