[GRASS-dev] Enable compilation with SQLite by deafut
Vaclav Petras wenzeslaus at gmail.com
Thu Jun 26 13:47:59 PDT 2014
On Thu, Jun 26, 2014 at 4:25 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Jun 26, 2014 at 10:06 PM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
> > Hi,
> > I just noticed that the default value in ./configure for SQLite support
> is
> > "no". Since sqlite is the default for GRASS 7 wouldn't make sense to
> have it
> > enabled by default?
> > For example, wxGUI does not even considers missing SQLite as a
> possibility.
> > I'm not sure if it is right and if modules are more robust. However, to
> make
> > compilation easier for (compilation) first time users, I suggest to
> change
> > the default to "yes".
> To me that sounds reasonable.
> OK, done in r60995
> > I don't know how to do it, configure(.in) is still mysterious for me.
> Very easy:
> - in "configure.in" line 253, take out the ", no"
> - then run autoconf-2.13
> - run configure ... to test
> Thanks, this was really easy, but my understanding is still low.
After autoconf2.13, I tested with make distclean, configure and make.
Vaclav
http://trac.osgeo.org/grass/changeset/60995
 Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140626/4630ca3c/attachment.html>
