[GRASS-dev] [GRASS GIS] #2355: g.mlist add parameter to check region
GRASS GIS trac at osgeo.org
Fri Jun 27 02:14:46 PDT 2014
 Reporter:  lucadelu     |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.1.0
Component:  Default      |     Version:  unspecified
 Keywords:  g.mlist      |    Platform:  All
      Cpu:  Unspecified  |
 Hi devs,
 I would like to have a parameter in g.mlist to check if maps (raster,
 vector ecc) are inside a region or not. It should work with the other
 parameters like pattern and exclude.
 The workflow could be something like this
 #user save the computational region
 g.region save=mytest
 #launch g.mlist with mytest region
 g.mlist type=rast patter=mypattern* region=mytest
 In this example all the maps with pattern ''mypattern'' and inside (I
 think the GIS operation could be touches, or using different one with
 another parameter operator like for v.select) the region ''mytest''
Ticket URL: <http://trac.osgeo.org/grass/ticket/2355>
