[GRASS-dev] [GRASS GIS] #2136: Create standard options for map or file base name (prefix)
GRASS GIS trac at osgeo.org
Fri Jun 27 05:55:55 PDT 2014
 Reporter:  wenzeslaus                   |       Owner:  grass-dev@…
     Type:  defect                       |      Status:  new
 Priority:  normal                       |   Milestone:  7.0.0
Component:  Parser                       |     Version:  svn-releasebranch64
 Keywords:  base name, prefix, basename  |    Platform:  All
      Cpu:  All                          |
Comment(by zarch):
 Thanks for your reviewing!
 [[BR]]
 Replying to [comment:20 hcho]:
 > I have a couple of comments:
 > * G_get_numb_of_decimals => G_get_num_decimals for naming
 > consistency with other get_num functions, but I'm not sure
 > if it deserves G_.
 Ok, I renamed it. I think that should be possible to use this function
 from the GRASS modules to determine, for example in r.horizon step
 parameter, how many decimal numbers are desired by the user.
 [[BR]]
 > Also, it's counting decimal numbers from a string. # decimals
 > has already been determined by a module before converting
 > a double to a string, so why do we need to get it again?
 Sorry I'm not sure that I get your point, I would like to use
 G_get_num_decimals from r.horizon and r.sun modules to define how many
 decimal numbers are required by the user.
 [[BR]]
 > * G_double_to_str: Its name is misleading because it
 > doesn't simply convert double to string, but also
 > replaces '.' with '_'.
 > Maybe, something like G_double_to_basename_format?
 yes, you are right, I think G_double_to_basename_format is better. I
 renamed it.
 [[BR]]
 > * G_get_format_name: I think you already renamed it
 > to G_generate_basename
 yes I forgot to update the trac list, thank you to point it out.
 [[BR]]
 > BTW, I prefer full names like G_get_basename_separator
 > and GRASS_BASENAME_SEPARATOR, but I know they are long...
 yes I think you are right they are longer but clearer, so I renamed them.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2136#comment:21>
