[GRASS-dev] [GRASS GIS] #2136: Create standard options for map or file base name (prefix)
trac at osgeo.org
Fri Jun 27 06:09:20 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Parser | Version: svn-releasebranch64
Keywords: base name, prefix, basename | Platform: All
Cpu: All |
Comment(by hcho):
Replying to [comment:21 zarch]:
> Thanks for your reviewing!
> [[BR]]
> Replying to [comment:20 hcho]:
> > I have a couple of comments:
> > * G_get_numb_of_decimals => G_get_num_decimals for naming
> > consistency with other get_num functions, but I'm not sure
> > if it deserves G_.
> Ok, I renamed it. I think that should be possible to use this function
from the GRASS modules to determine, for example in r.horizon step
parameter, how many decimal numbers are desired by the user.
> [[BR]]
> > Also, it's counting decimal numbers from a string. # decimals
> > has already been determined by a module before converting
> > a double to a string, so why do we need to get it again?
> Sorry I'm not sure that I get your point, I would like to use
G_get_num_decimals from r.horizon and r.sun modules to define how many
decimal numbers are required by the user.
Ah! So you take an input parameter from the user as a string and feed it
directly to this function. I thought you already converted double to
string by the time you call this function, then you should already know
how many decimals you have because you used that info for conversion
already. This function now makes sense to me.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2136#comment:22>
