[GRASS-dev] [GRASS GIS] #2350: G7: r.texture large file support problem
trac at osgeo.org
Sun Jun 29 03:06:35 PDT 2014
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: unspecified
Keywords: LFS, r.texture | Platform: Linux
Cpu: x86-64 |
Comment(by glynn):
Replying to [comment:2 neteler]:
> > Why do you believe that this is related to LFS?
> I got the idea from
Range of data: min = -2147483648 max = -2147483648
LFS issues wouldn't (directly) cause this. -2147483648 is -2^31^ = INT_MIN
= (int)0x80000000. I believe that it arises from casting a double to an
int where the value isn't representable as an int:
#include <stdio.h>
int main(void)
double x = 1.0e12;
double y = 0.0 / 0.0;
printf("%g %d\n", x, (int) x);
printf("%g %d\n", y, (int) y);
return 0;
produces:
1e+12 -2147483648
-nan -2147483648
> > These warnings are generated by Rast_close() or Rast_unopen(), and
> > correspond to a rename() system call failing.
> Would it be possible to make the errno more visible or "clear"?
Try r61048.
> Here the various permissions:
What are the permissions and ownership for
/grassdata/patUTM32/alba_classification/.tmp/blade21
/grassdata/patUTM32/alba_classification/cell_misc/*
Ticket URL: <https://trac.osgeo.org/grass/ticket/2350#comment:3>
