[GRASS-dev] [GRASS GIS] #2326: Command functions in grass.script.core miss a correct error reporting
GRASS GIS trac at osgeo.org
Sun Jun 29 03:41:48 PDT 2014
 Reporter:  wenzeslaus          |       Owner:  grass-dev@…
     Type:  enhancement         |      Status:  new
 Priority:  major               |   Milestone:  7.1.0
Component:  Python              |     Version:  svn-trunk
 Keywords:  script, exceptions  |    Platform:  All
      Cpu:  Unspecified         |
Comment(by glynn):
 Replying to [comment:16 wenzeslaus]:
 > They say that ''The data read is buffered in memory, so do not use this
 method if the data size is large or unlimited.''
 If the data would otherwise be sent to the terminal, memory consumption
 won't be an issue. But there are a few modules which can produce vast
 amounts of data on stdout (e.g. r.out.ascii, r.stats).
 Apart from memory consumption, many modules print progress output, and you
 want that to appear as it's generated, not all at once when the module
 terminates.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2326#comment:17>
