[GRASS-dev] [GRASS GIS] #2339: wxGUI.Nviz flickering
trac at osgeo.org
Sun Jun 29 06:44:00 PDT 2014
Reporter: hcho | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: Nviz | Platform: Linux
Cpu: x86-64 |
Comment(by annakrat):
Replying to [comment:2 hcho]:
> Fixed in r61053. Please test it on Windows and Mac.
Works here on Ubuntu. For whatever reason I thought that it is by default
double buffered but apparently not. Just quoting from the documentation to
have it here explained:
''If the attribute list is not specified at all, i.e. if this parameter is
NULL, the default attributes including WX_GL_RGBA and WX_GL_DOUBLEBUFFER
are used. But notice that if you do specify some attributes you also need
to explicitly include these two default attributes in the list if you need
them.''
I will test on Windows but the change for Windows platform (and Mac) was
not necessary because there was no such problem (double buffering was used
by default).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2339#comment:3>
