[GRASS-dev] PyGRASS Module error handling
Vaclav Petras
wenzeslaus at gmail.com
Mon Jun 30 08:43:20 PDT 2014
when writing tests which involve PyGRASS Module class I found that at some
occasions the error messages are quite confusing.
First when you try to run one module twice, you get AttributeError:
>>> from grass.pygrass.modules import Module
>>> from subprocess import PIPE
>>> m = Module('r.info', map='elevation', run_=False, stdout_=PIPE)
>>> m.run()
>>> m.outputs['stdout'].value
>>> # running for the second time
>>> m.run()
Traceback (most recent call last)
AttributeError: 'str' object has no attribute 'fileno'
Second, when you confuse m.inputs['map'].value with m.inputs['map'] (which
is pretty easy error to do) you get "TypeError: deletions are implemented
differently for unicode":
>>> # this is OK
>>> m.inputs['map'].value = 5
TypeError: The Parameter <map>, require: raster, get: <type 'int'> instead
>>> # this is not OK
>>> # confusing parameter object and parameter value
>>> m.inputs['map'] = 'aspect'
TypeError: deletions are implemented differently for unicode
With the former it depends what is actually allowed. Than it is probably
easy to fix. With the later, no easy solutions come to my mind.
With my tests I was actually asserting m.outputs['stdout'] for true which
is always true instead of asserting m.inputs['stdout'].value. I don't know
how to avoid this mistake in general.
Does this make sense to you or do you think that I and PyGRASS users should
be just be more careful?
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140630/2b101844/attachment.html>
