[GRASS-dev] Parallelize a job using multiprocess python library without destroying environmental variable
Javier Martínez-López
javi.martinez.lopez at gmail.com
Mon Jun 30 11:17:05 PDT 2014
Hi Annalisa,
I still need to learn a lot about this and have not tested Vaclav's
advice yet, which is probably the best way to go, but you can take a
look at some scripts I wrote for doing this:
https://github.com/javimarlop/eHabpy/blob/master/pas/tmp/parallel_segmentation_pca.py
https://github.com/javimarlop/eHabpy/blob/master/pas/parallel_grass_example.py
They are working for me, but as Markus Metz also mentioned me once, if
you are not using a cluster and there is a lot of writing/reading from
the same hard disk, you will probably not speed up considerably the
processing. In any case, I am also very interested in further
developing this script, so any ideas are welcome!
Cheers,
Javier
On Mon, Jun 30, 2014 at 4:05 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Mon, Jun 30, 2014 at 5:21 AM, Annalisa Minelli <annagrass6 at gmail.com>
> wrote:
>> Hi all,
>> I'm attempting to parallelize a job in a python script using multiprocess
>> library in grass70.
>> I had a look at the following links:
>> http://grasswiki.osgeo.org/wiki/Parallel_GRASS_jobs
>> and http://grasswiki.osgeo.org/wiki/Parallelizing_Scripts.
>> I would like to work in the same location but in different mapsets because
>> my jobs touch the region settings, but I don't know how to set separate
>> mapset for separate jobs.
>> Since now I discovered that this processes, if run in the same mapset,
>> clean all the environmental variables (GISDBASE, LOCATION, MAPSET) so then
>> GRASS does not start anymore and I have to restore the .grass70/rc file..
>> can anyone hint me on how to set different mapsets for different jobs?
> First, look at the PyGRASS GridModule [1] whether this can help you.
> For general case, there is unfortunately no API. From what I understand, you
> have to create a file "gisrc" somewhere and then do something like env =
> copy(os.environ) and change GISRC there to your custom "gisrc". Then you the
> change the mapset and region by standard GRASS means but you must pass `env`
> parameter to all command/module calls (env is used by Python subprocess to
> set environment just for one process).
> Note that GISRC, GISBASE and LOCATION are (system) environmental variables
> while GISDBASE, LOCATION_NAME and MAPSET are GRASS GIS session/environment
> variables and are stored in "gisrc" file. I don't have an idea what LOCATION
> variable is for (it contains full path to the mapset).
> I would be glad to hear what others think about this.
> You can of course read source code of GridModule, rendering in wxGUI,
> g.gui.animation, or the following snipped but I don't say that it will be
> easy to understand and there might be a lot of imperfections.
> Vaclav
> # we rely on the tmp dir having enough space for our map
> tgt_gisdbase = tempfile.mkdtemp()
> # this is not needed if we use mkdtemp but why not
> tgt_location = 'r.out.png.proj_location_%s' % epsg_code
> # because we are using PERMANENT we don't have to create mapset
> explicitly
> tgt_mapset_name = 'PERMANENT'
> src_mapset = Mapset(src_mapset_name)
> # get source (old) and set target (new) GISRC enviromental variable
> # TODO: set environ only for child processes could be enough and it
> would
> # enable (?) parallel runs
> src_gisrc = os.environ['GISRC']
> tgt_gisrc = gsetup.write_gisrc(tgt_gisdbase,
> tgt_location, tgt_mapset_name)
> # we should use a copy and pass it but then it would not be possible to
> use create_location
> os.environ['GISRC'] = tgt_gisrc
> if os.environ.get('WIND_OVERRIDE'):
> old_temp_region = os.environ['WIND_OVERRIDE']
> del os.environ['WIND_OVERRIDE']
> else:
> old_temp_region = None
> # these lines looks good but anyway when developing the module
> # switching location seemed fragile and on some errors (while running
> # unfinished module) location was switched in the command line
> try:
> # the function itself is not safe for other (backgroud) processes
> # (e.g. GUI), however we already switched GISRC for us
> # and child processes, so we don't influece others
> gcore.create_location(dbase=tgt_gisdbase,
> location=tgt_location,
> epsg=epsg_code,
> datum=None,
> datum_trans=None)
> # Mapset object cannot be created if the real mapset does not exists
> tgt_mapset = Mapset(gisdbase=tgt_gisdbase, location=tgt_location,
> mapset=tgt_mapset_name)
> # set the current mapset in the library
> # we actually don't need to switch when only calling modules
> # (right GISRC is enough for them)
> tgt_mapset.current()
> [1] http://grass.osgeo.org/grass71/manuals/pygrass/modules_grid.html
>> All the best,
>> Annalisa
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
