[GRASS-dev] addon compilation error
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Jun 30 15:05:47 PDT 2014
That doesn' t seem to work either, I am getting the same error message
after adding the py extension
On 30-06-14 17:24, Vaclav Petras wrote:
> On Mon, Jun 30, 2014 at 10:23 AM, Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
> I wrote a little addon r.random.weight and added it to the addon
> repository:
> https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.random.weight/r.random.weight
> However, when trying to install it in grass (7) via the
> addon-extensions function, it fails, with the message below:
> Fetching <r.random.weight> from GRASS-Addons SVN (be patient)...
> Compiling...
> make: *** No rule to make target
> `/tmp/tmpXHVzn1/r.random.weight/scripts/r.random.weight',
> needed by `script'. Stop.
> ERROR: Compilation failed, sorry. Please check above error messages.
> Other addons install fine. Can anybody tell me what I should do to
> make this work?
> Try to add .py extension. Other Python scripts have it.
> https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.basin/r.basin.py
> Best wishes
> Paulo
> grass-dev mailing list
> grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140701/8f164344/attachment.html>
