[GRASS-dev] r.unpack: unhelpful error message when projection info does not match
Anna Petrášová kratochanna at gmail.com
Sat Mar 1 19:23:27 PST 2014
On Fri, Feb 28, 2014 at 5:14 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> On 28 February 2014 15:38, Markus Neteler <neteler at osgeo.org> wrote:
> > Ideas? thanks
> I think the attached patch should fix the problem (I have no time to
> test it), but I don't know if it broke something else.
> I saw the function compare_key_value_text_files is used only in
> r/v.unpack and temporal/stds_import.py, Soeren the attached patch
> could create problem in this file?
The diff looks reasonable. Since it is used in the temporal framework for
the same purpose, it should be fine I think. As Glynn mentioned, this
function shouldn't be in core, so how about creating
python/scripts/utils.py? Some of the functions in gui could be moved there
too.
Anna
> > Markus
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140301/6ed1de72/attachment.html>
