[GRASS-dev] [GRASS GIS] #1776: Python error by startup
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Mar 3 14:03:12 PST 2014
Hi Marisn,
Yes, there is no error message anymore.. thanks!
Should I mark this ticket as fixed, or will you do that?
Paulo
> Reporter: pvanbosgeo | Owner: martinl
> Type: defect | Status: assigned
> Priority: normal | Milestone: 7.0.0
> Component: Startup | Version: svn-trunk
> Keywords: language settings, locales, i18n | Platform: Linux
> Cpu: x86-64 |
> Comment(by marisn):
> Paulo, could you, please, try GRASS 7 after r59176 ? I changed a bit
> language overriding code in startup script to avoid problems like you had
> and still be able to keep language override.
