[GRASS-dev] Plural form support in GRASS 7 translated messages
Glynn Clements
glynn at gclements.plus.com
Mon Mar 3 17:40:30 PST 2014
Maris Nartiss wrote:
> Currently _n() works only in C code. I hope some of Python gurus will
> clarify/implement same thing for Python parts of GRASS.
Python code uses gettext.install(), which adds several functions to
the built-in namespace:
def install(self, unicode=False, names=None):
import __builtin__
__builtin__.__dict__['_'] = unicode and self.ugettext or self.gettext
if hasattr(names, "__contains__"):
if "gettext" in names:
__builtin__.__dict__['gettext'] = __builtin__.__dict__['_']
if "ngettext" in names:
__builtin__.__dict__['ngettext'] = (unicode and self.ungettext
or self.ngettext)
if "lgettext" in names:
__builtin__.__dict__['lgettext'] = self.lgettext
if "lngettext" in names:
__builtin__.__dict__['lngettext'] = self.lngettext
If we want _n(...) to work in Python, it will need to be added
explicitly with e.g.
import __builtin__
__builtin__.__dict__['_n'] = __builtin__.__dict__['ngettext']
This should immediately follow the gettext.install() call, which
exists in the following files:
scripts/v.krige/v.krige.py
lib/python/temporal/core.py
lib/python/script/core.py
lib/init/prompt.py
lib/init/grass.py
lib/init/grass.py
Some of these use unicode=True and some don't. Setting unicode=True
binds "_" to "ugettext", which returns a unicode string. The default
setting of unicode=False binds "_" to "gettext", which returns a byte
string.
Note that passing a unicode string to a function which expects a byte
string (e.g. subprocess.Popen(), or the .write() method of streams not
explicitly opened via codecs.open()) will result in it being encoded
using the default encoding (which is usually ASCII), not the locale's
encoding.
So don't use unicode=True unless you're either prepared to explicitly
handle the encoding issues when interfacing with system functions
(command execution, I/O, etc), or you're only interacting with the
system via a library which deals with this for you (e.g. wxPython).
