[GRASS-dev] Character encoding of module i.atcorr files
Vaclav Petras wenzeslaus at gmail.com
Mon Mar 3 18:35:53 PST 2014
On Mon, Mar 3, 2014 at 9:18 PM, Glynn Clements <glynn at gclements.plus.com>wrote:
> Source code doesn't just have to work with the interpreter. It needs
> to work with text editors, web browsers, revision-control systems,
> printers, etc. Some of those understand coding cookies, some don't.
> The main problem with coding cookies is that software which
> (explicitly or implicitly) converts between encodings typically leaves
> the cookie unchanged. Which is why libraries such as chardet typically
> treat coding cookies as little more than a hint or fallback.
What are coding cookies?
My search brought me to Cookies and Coding event which is for sure great
but apparently not related to current discussion.
[1] http://www.meetup.com/Women-Who-Code-Austin/events/160041362/
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140303/8477d767/attachment.html>
